How come there is not an inner radius setting when using 4th axis rotary parallel strategy?
kksAZZV7
kksAZZV7
Hello
How come there is not a possibility to adjust an inner radius on a rotary parallel milling strategy?
Seems like it is just missing? or am I doing something wrong?🤔 (see attached picture)
I look forward to hear from you.
Br. Kristoffer
seth.madore
It's not missing, it's just not a value that belongs in that specific toolpath. You can control how deep it goes with other bodies, touch/avoid and Model overrides
Seth Madore
kksAZZV7
Hmm.. Ok. I think it would be nice and easy to be able to control a inner radius...
Thank you for the quick reply.
CRANDALLPRECISION
Every software I've used you need a tube surface to control that. At least fusion is parametric so easy to change
