'Horizontal' routing of contour cutouts (UCCNC)
I'm using Fusion 360 with UCCNC and a Stepcraft S600. I need to route contour cutouts in some plastic enclosures so that I can fit various connectors. This particular enclosure is too large to be placed on the machine bed and routed 'vertically' along the Z-axis in the usual manner. Instead, I have a right-angle bracket that allows me to fit the spindle at 90 degrees - i.e. horizontal.
When it comes to Fusion 360, I have defined a setup normally, with the machine coordinate system having the Z-axis vertical. Then, for the 2D contour operation, I define a new coordinate system in the tool orientation options with the X-axis remaining the same, and the Y-axis and Z-axis swapped:
Horizontal routing
It all looks OK, and the simulation runs fine. But when I come to generating the g-code with the UCCNC postprocessor, I get an error. Here is the output:
Information: Configuration: STEPCRAFT UCCNC Information: Vendor: UCCNC Information: Posting intermediate data to '\\desktop-4d5vfvn\Users\Eva\Desktop\CNC\1001.nc' Information: Total number of warnings: 4 Error: Failed to post process. See below for details. ... Code page changed to '1252 (ANSI - Latin I)' Start time: Monday, November 18, 2019 3:37:21 AM Warning: function getProgramNameAsInt does not always return a value Warning: function getProgramNameAsInt does not always return a value Warning: function getProgramNameAsString does not always return a value Code page changed to '20127 (US-ASCII)' Post processor engine: 4.53.0 9 Configuration path: C:\Users\Anthony\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\stepcraft uccnc.cps Include paths: C:\Users\Anthony\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts Configuration modification date: Thursday, May 23, 2019 10:53:08 AM Output path: \\desktop-4d5vfvn\Users\Eva\Desktop\CNC\1001.nc Checksum of intermediate NC data: 6a17f4a0ff0b618b216e36039ccf2bf7 Checksum of configuration: 78b7a8ad1915626fc7bf1f0bd2b15104 Vendor url: http://www.cncdrive.com/ Legal: Copyright (C) 2012-2018 by Autodesk, Inc. Generated by: Fusion 360 CAM 2.0.6670 ... Warning: Work offset has not been specified. Using G54 as WCS. ############################################################################### Error: Tool orientation is not supported. Error at line: 721 Error in operation: '2D Contour2' Failed while processing onSection() for record 433. ############################################################################### Error: Failed to invoke function 'onSection'. Error: Failed to invoke 'onSection' in the post configuration. Error: Failed to execute configuration. Stop time: Monday, November 18, 2019 3:37:21 AM Post processing failed.
The error appears to be 'Tool orientation is not supported'. Am I asking too much of UCCNC? What can/should I do?
Many thanks.
