Horizontal milling HEIDENHAIN TNC 407
KonstF
Message 1 of 1
KonstF
Hi all.
I use a Hermle 900 E universal machine. In the main version, the Z-axis has a vertical arrangement, but the machine also has a horizontal spindle (located on the Y-axis). Can you advise how to edit the Heidenhain tnc 407 postprocessor to change the axis using the tool from Z to Y ?
The tool call string should have the following format:
TOOL CALL 1 Y S...
and accordingly, further in the executable file, Y should change to Z.
Replies (0)
