Home interface?
Home interface?
mwbarre1
Home interface?
mwbarre1
So I'm learning to use the 'home' interface, and I have my projects listed. If I open up my latest project, I can filter/search for the latest projects. I think it's a great idea. However, it doesn't work. I just finished some drawings and now I need to share them with colleagues. But if I search for 'modified date', and flip the Up/Down arrow to see oldest first or newest first, it doesn't show the drawings at all. What's going on? I'm pretty sure there are no other filters active.
Can I ask a question? Why did it change? I liked the older project/files lists. They made sense, they were easy to sort through... I don't like this new layout. And the option to use an older interface is gone too... so I'm forced to use something I don't like now.
Matt B. (Uni of Ariz)
programming2C78B
The old layout is still there, you just have to be "in" a project to see the old grid icon.
When in HOME, ensure you are also in the correct folder/location. The search function is stupidly not set to be a global search.
Please click "Accept Solution" if what I wrote solved your issue!
obulesub
Hello, @mwbarre1,
Just checking in did the response shared by @programming2C78B  help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
Obulesu | Community Manager
mwbarre1
I need to clear up a misunderstanding. Due to an older system (5 years), there must have been some sort of lag between the updated version and the previous version when it kicked over. Fusion360 had it's latest update, and when I restarted Fusion it showed blanks for projects, blanks for files, blank everything. I restarted the PC, nothing changed. Then I came to the forum and made my complaint when nothing was showing up. I went to lunch, let it reboot and whammo! Everything is back. The home interface isn't so bad, but it wasn't updating fast enough. I've since watched it catch up 10minutes after I had saved a project.
