I am trying to cut a 15/64 (0.234") hole in 1/2" acrylic using an 1/8 O flute bit on my 3XXL with the Carbide router. I am having the hardest time getting the hole to be accurate in dia. I am using Fusion360 to generate toolpaths. The holes are turning out to be smaller than the 15/64". I have tried to make the holes bigger but find that the consistency is just not there. One hole will be good then the next will be too small. I have also tried several different toolpath types but still can get accurate holes. I have to be missing something or maybe the 3XXL is not rigid enough or maybe the stepper motor increments are holding me back. I am using the Amana 51445-K 1/8 O flute bit with a 1/4" shank. I was hoping the 1/4" shank would help with deflection.What type of tool path would you recommend and what feeds and speeds? Or any other advice would be awesome.ThanksRyan Hensley
