Holding Gears - 3 axis mill
richardsalzman
richardsalzman
I am starting to work on a project with gears. I have been thinking about the best way to hold them. For the first side, I was thinking about using the cyanoacrylate glue approach. But I am not sure how to do the second side. Any thoughts?
This image is not exactly what I will be machining, but something in this realm:
Here is a link to the drawing:
https://a360.co/4rXNLEK
seth.madore
Depending on the material (steel, alum, plastic), I'd be totally comfortable holding them in aluminum soft jaws.
Seth Madore
richardsalzman
Thanks Seth.  I forgot to mention that this will be made from 6061.  Just so I understand you correctly, you would machine one side in the first operation including the gear teeth, then flip it over, put it in round soft jaws that press on the outside diameter of the teeth (as if it were just a cylinder) and machine side two?  I am assuming you would machine something into the jaws to register the gear position.
Some time ago, you helped me with soft jaws for a flywheel (see below).  It seems like you are suggesting a similar technique.  Can you please jog my memory, why didn't we make the registering piece that fits into the flywheel round instead of the shape shown below?  Looking at the drawing, only the left and right sides make contact with the model, the top and bottom of this shape do not contact the flywheel.  Was the intent to limit it to only two points of contact?
richardsalzman_1-1771277211048.pngrichardsalzman_1-1771277211048.pngrichardsalzman_2-1771277228613.pngrichardsalzman_2-1771277228613.png
Thanks, as always... Richard
seth.madore
I would just machine a diameter in the jaws, not the actual profile of the teeth. The idea above is exactly what I'd do; machine a bore and leave a post that locates on a unique spot. The diamond shaped post is to account for size variation while maintaining rotational accuracy (around the Z) for the part.
Seth Madore
programming2C78B
How many? Just use round soft jaws. It doesnt matter too much if the teeth compress in the jaws because youre going to find center anyway.
Please click "Accept Solution" if what I wrote solved your issue!
lauri_barnhart
Hello, @richardsalzman,
Did the information provided by @seth.madore help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
