Help with uniform tool path generation and overhang operations
mrizia
Message 1 of 8
mrizia
I'm new to CAM in Fushion 360. I was trying to generate a uniform roughing tool path (wrapped around all surfaces) around a boiler. But I'm seeing that the tool path does not consider the inward slopes/ramp surfaces/overhangs. I am using 2D adaptive clearing. I tried with 2 separate stocks. Maybe there is a better way to do it.
I'd really appreciate any help or suggestions.
Attaching the file here--
Replies (7)
Message 2 of 8
seth.madore
Let's have a brief chat about manufacturing processes...
If you are trying to machine this in one setup (on a 3 axis machine) out of a solid piece of material, you are going to be in for a rough time. The undercut sloped surfaces are not at all accessible. You would need to lay the part down on its side to have even a chance of making this part. Further, your toolholder is crashing through the part, due to your tool not sticking out far enough.
Am I misunderstanding what you are trying to accomplish?
Seth Madore
Message 3 of 8
mrizia
Thank you for your reply. I am not going to machine the part. I am only concerned about the tool path, with a rough offset. I want to get the tool endpoint coordinates for another purpose, so I'm not really concerned about the tool crashing into the body. I just need a wrapped tool path. It can be more than one operations. But till now I'm unable to get into the inward slopes or under overhangs.
Message 4 of 8
seth.madore
Could you mark up a screenshot indicating where you want the toolpath to reach? I want to make sure we understand each other. You could also use the Screencast to add audio to a short video if you want
Seth Madore
Message 5 of 8
mrizia
I've attached a screenshot. I am trying to reach the slope under the model. As you can see, it just takes on the rectangular geometry over it. Here, I only have a single component; I'm also working on more complex structures with similar issues.
Message 6 of 8
seth.madore
So, like this?
Could you elaborate on what exactly you are trying to accomplish so we can better answer your question? If it's super secret stuff feel free to PM me I suppose 🙂
Seth Madore
Message 7 of 8
seth.madore
In addition;
What sort of machine and control do you have access to, and what is the material that you will be cutting?
Seth Madore
Message 8 of 8
mrizia
I'm not going to machine the part. I'll use the tool path data (g-code file) for another project.
