Help With Toolpaths Over Multiple Parts
Hello, I am trying to add a ramp cut to all 4 of the same pieces. For some reason the tool path is only generating on the first part even though all 4 chains are selected. I tried adding a separate ramp cut to a part that the tool path would not generate and I am getting errors that says no passes to link and empty tool path. I would appreciate any help.
Thank You
Steinwerks
Adding all four of the bodies to your Setup fixes the issue since it only looks at them for the geometry queues unless added specifically in the toolpath:
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Thank you very much! That fixed the problem
