help with fusion 360 cam and revolver model
Message 1 of 20
Hi im having trouble putting these radius slots on this revolver cylinder i created. I cant get the tool path to link/ do anything .im also using the mill/turn function in cam.
Im pretty sure its with the setup. I created a test model with a bunch of slots on it and it works just fine. hope someone can help me thanks. ill upload the model.
Replies (19)
Message 2 of 20
daniel_lyall
Your model needs to be made a solid before you try anything else, highlight the model with a left to right-drag then in the surfaces workspaces stitch it to together, then delete all the empty components folders.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 20
I sent the wrong one by mistake here is the solid model.
Message 4 of 20
seth.madore
The file you attached has no setups or toolpaths in it. We have no idea where you are running into trouble or what has gone wrong. Please share something that shows some attempts at a toolpath, as well as your other sample piece that you mentioned in your first thread.
Seth Madore
Message 5 of 20
mesacrash
Are you planning on making this cylinder? If so, there are some issues with the cylinder. The flutes are supposed to strengthen the cylinder, but yours have stress risers. There are others. I have a lot of experience manufacturing cylinders. If you would like, we could talk about it.
Message 6 of 20
well ive managed to get it to work sort of but id like to be able to come in from the face of the part and run it to the back of the part and repeat on next slot. ill post what i have bare with me as im new to cam.
Message 7 of 20
daniel_lyall
Is this what you won't to archive
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 20
yes now how were you able to do this? can you teach me..?
Message 9 of 20
daniel_lyall
What machine are you going to be machining this on, there are a lot of ways it can be done.
Daniel Lyall
The Big Boss
Mach3 User
Message 10 of 20
mesacrash
Now the ball endmill has been used; eliminating the stress riser in the flutes. For aesthetics, try raising the tool in the Z axis while continuing in the Y axis. Check it out.
Message 11 of 20
daniel_lyall
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 20
daniel_lyall
Here is one way to do a toolpath in Fusion.
There are a few different ways to do toolpaths in Fusion from sketches to surfaces like above defeaturing a model so on.
Any other questions fire away or If I am going to fast in the screencast I can do it again slower.
What is shown is not a finishing toolpath also there are mistakes in the video and a fix just for reference.
Daniel Lyall
The Big Boss
Mach3 User
Message 13 of 20
mesacrash
Here is a link to the type of cutter often used for fluting a cylinder:  https://www.mscdirect.com/product/details/03170339
This will allow the flute to have 2 different radii.
Of course you could use a ball end mill in a CNC, as it can travel in 2 axis at once.
Message 14 of 20
johnswetz1982
How do you get 2 different radii with that cutter?
Message 15 of 20
mesacrash
1/4" Radius x 3" Diam (which has a radius of 1-1/2").
Message 16 of 20
daniel_lyall
@mesacrash  That is a milling cutter I don't think it would work too well with mill turn.
Daniel Lyall
The Big Boss
Mach3 User
Message 17 of 20
mesacrash
I am new to cam so I have nothing to respond with. I can draw it and mill
it manually but...
Message 18 of 20
daniel_lyall
@mesacrash  That is why you just ask no one is going to be a troll over any question or Idea you have.
Daniel Lyall
The Big Boss
Mach3 User
Message 19 of 20
mesacrash
Read the attached file, please. I think you may enjoy it. It is from the archives of American Handgunner magazine 1997. I am Charlie in the article.
Message 20 of 20
seth.madore
@mesacrash  pretty cool stuff! Man, I remember buying that magazine when I was a kid. Best expenditure of summer job income (in my eyes anyways)
Welcome to the world of CNC!
Seth Madore
