Message 1 of 9
Hi All,
I have a part I'm trying to cut out using a 2D contour. Its 72mm square, with 17mm radiused corners. With a less than rigid machine, I can only take side cuts of 0.2-0.3mm at a time. Preparing the stock only 1mm oversized helps, but using a 2D contour, it tries to cut the corners off in one go, as you can see in the first image. Obviously I can do multiple roughing passes to sneak my way to the line and nibble off the corners, but I'd need about 45 passes just to cut out one of these (second image).
Is there a better/faster way to attack the corners?
Regards
Neal
