Can I get a recommendation on the toolpaths to use for this rosette? I'd like to machine the ring separately, because I believe I can use a bigger bit (.313") and save time. I'm using a .4mm flat nose on the smaller rectangle-ish portions to get the most detail. But I want to cut one big circle instead of a bunch of circle segments, to minimize any hand work as the pockets between the circle and the shapes meet. I've tried the circle toolpath, but can't get it to machine where I want.
Side note: I can't seem to erase my bodies (inlay pieces) and expose the bottom of the pocket to select it instead. When I erase the bodies, the whole thing just goes away, not revealing a pocket or void in the stock...its like it just didn't exist. Why is that?
Thank you big brains!
