Help modifying post processor for Laguna SmartShop M
jeffhammond
jeffhammond
the basic Laguna post processor writes this at the beginning of the program and after each tool change then again at the end:
N10(Program name: 1001)
N11(Program comment: )
(T2 D=9.525 CR=0. - ZMIN=-12.573 - FLAT END MILL)
N12G17G40G90
N13G71
N14D0
N15G00Z0.
..that last line shown, G00Z0. ...makes the bit go to the top of the stock (which is where my origin is set).. it will then drag across the stock until the cutting begins.. if my origin were set from the bottom of the material, the bit would try to go to that point..
i've been editing/deleting this line after the fact and it runs fine (as long as my Z is sitting above the stock prior to running)..
so, can someone tell me what i need to change in order for this not to happen and have the machine go a safe Z height at this point(s) in the program..?
-or-
show me how to prevent the processor from writing this line?
thanks!
(apparently, the D0 is weird but it works on other Laguna machines.. on the SmartShop M, i don't think it works that way)
i'm using this:
https://cam.autodesk.com/hsmposts?p=laguna
the only modification i've made so far is the file type is MMG instead of PRG
Boopathi_Sivakumar
@jeffhammond
Make a copy of the post processor file and do the changes
To Avoid posting the line in the start of your program you have to go to the below code
    // retract to safe plane
    writeRetract(Z);
    currentWorkOffset = undefined;
    forceXYZ();
and forwd slash to the write retract like this
    // writeRetract(Z);
    forceXYZ();
and same for to avoid at the end of the post at the function writeretract you get to see this code
    case Z:
      writeBlock("D0");
      writeBlock(gMotionModal.format(0), zOutput.format(0));
      retracted = true; // specifies that the tool has been retracted to the safe plane
      break;
Add Forward slash before to this code
the final program will be like this
    case Z:
      writeBlock("D0");
      // writeBlock(gMotionModal.format(0), zOutput.format(0));
      break;
Save this file and check your post with different files and if you don't found any issues you can processed with the machine.
Poke back us if you have any doubts
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
jeffhammond
Awesome Boo! Smiley Wink
I've made the edits and it looks good on my computer.. i'll try it on the machine today.
thank you!
ICanSpinIt
Thank you for this! Spent the whole day trying to figure out how to not have to manually enter.
You wouldn't by chance know how to code it so the machine returns to defined G53 values?
Currently it returns to work origin values but at a Z0 because of the "//"
