Help machining a part
Message 1 of 10
I'm new to Fusion 360 and am having problems machining the attached part. Its just a series of grooves. Can anyone help ?
Replies (9)
Message 2 of 10
johnswetz1982
Was this part imported from some other program?
Message 3 of 10
Yes it was a solidworks part
Message 4 of 10
johnswetz1982
I think you are going to have to create a sketch and then project a/both edges to the sketch and then use either the edges to control a 2D Contour operation or create center lines and use those to control a Trace operation.
Message 5 of 10
seth.madore
@johnswetz1982  you sir, are awarded NO POINTS!
We can totally do this with 2D Contour, clever selections and turning on Stock Contours. Oh, also have to put a value in Stock To Leave (axial). File is attached
Seth Madore
Message 6 of 10
johnswetz1982
Well @seth.madore I can retire early today cause I learned my new fact for the day. I did not know that you could drive off of a small contour and "extend" it with stock contours. Certainly easier than my solution.
Message 7 of 10
seth.madore
But wait, there's more!
This doesn't apply to the part in this thread, but with Stock Contours turned on and Roughing passes enabled, you can essentially turn 2D Contour into a 2D Pocket routine. This is gold for those contours that fail with pocket (radii or chamfers where pocket breaks out)
Seth Madore
Message 8 of 10
MoshiurRashid
As you imported the part from solidworks, I suggest you export it to another format from solidworks. (Like, igs) and have a try
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 9 of 10
johnswetz1982
Importing the part from solidworks was fine. I was questioning because there was no design history so that was a tip off it was designed else where. I was looking for a sketch to drive the contour operation, but it was pointed out to me my method was not the easiest and there was simpler ways of performing operation.
Message 10 of 10
schneik-adsk
@MoshiurRashid  I'm sorry this answer is wrong and not helpful.
Kevin Schneider
