Help finding post processor for Touch 2000 Lathe Software
j.dittmar01
j.dittmar01
I am trying to load a fusion 360 CAM program onto a Fryer EL-18 Lathe that has Touch2000 software running on Window's Millennium Edition.
I've tried google searches, checking the post processor library and digging through the post processors on Fusion itself to try and find one that works and I'm just not educated enough to know for sure.
Any help would be appreciated.
engineguy
@j.dittmar01
Do you have some G Code samples either from the machine or the Operators Manual that can be looked at, quite possible that there are Post Processors that will generate the code you need with no or minimal editing.
If you have any G Code files then attach them to your reply using the "Attachments" facility below.
j.dittmar01
These are from the machine itself
j.dittmar01
Forgot to add, the output extension for the machine is .PMC, it doesnt seem to accept anything else/won't recognize any other extension.
engineguy
@j.dittmar01
Not managed to find a Post Processor that outputs the same code yet, still trying different ones.
Regarding the .PMC extension, that is easily changed in any Post Processor, just a matter of finding one that is close enough code wise 🙂
