HELLO!. I want to change G28 to G53.
j.hong3MP6V
j.hong3MP6V
HELLO!
When moving to the home position after the cycle,
M09
G28 G91 Z0.
G90
G49
G28 G91 X0. Y0.
G90
M30
It's being printed like this.
I would like to change this so that G53 G91 X700 Y-30 can be output from G28 G91 X0.Y0. Help me.
I am sorry that I am not good at English
Oguzhan_Sezer
Which post processor do you use? Some post processors has options for changing home positions. Modifications are required for post processors without this feature.
Oğuzhan SEZER
Manufacturing Engineer
Technical Support Specialist / Artı & Artı Teknoloji Hizmetleri
j.hong3MP6V
I changed it the same way.
M09
G28 G91 Z0. -----> G53 G91 Z0.
G90
G49
G28 G91 X0. Y0.
G90
M30
It only changes like this.
Oguzhan_Sezer
Okey. To change that, we can override the G28.
  • In the "define home positions" section of the post, you must enter the values you mentioned in the first post (X700, Y-30).
  • Then let's force write G53 instead of G28 output.
  • Also, let's set the "safePositionMethod" value to G53 so that G53 is selected as the standard.
  • That's all.
For example, I edited a Fanuc post. You can also look at the attached file.
Oğuzhan SEZER
