HELLO!. I want to change G28 to G53.
j.hong3MP6V
j.hong3MP6V
HELLO!
When moving to the home position after the cycle,
M09
G28 G91 Z0.
G90
G49
G28 G91 X0. Y0.
G90
M30
It's being printed like this.
I would like to change this so that G53 G91 X700 Y-30 can be output from G28 G91 X0.Y0. Help me.
I am sorry that I am not good at English😫
Bunga777
This is a Japanese forum, but you can also use English, no problem(^_^;)
I think you are talking about Turning somehow, so I will talk about it in Fanuc Turning.cps.
In the Post property when outputting the post, there are settings in the area surrounded by the red frame in the image below.
And Enter each position and change "Safe Retracts" to "G53" to output.
Since you want to output X and Z axes on the same line at the same time, set "Both same line" to "Safe retract style".
The output result here.
If the timing of output does not meet your expectations, you may need to make some improvements.
P.S.
After a closer look, it doesn't seem to be a lathe. lol I'll check it out a bit.
Bunga777
Sorry, my earlier post was talking about lathes, but since you are apparently talking about milling, could you please give me the details of the post you are currently using?
j.hong3MP6V
ありがとうございます。
普通のFANUC POSTです。
