Helical groove cutting lathe
anttonijamsa
anttonijamsa
Hello!
I wonder if fusion360 is able to help me create this toolpath.,
Imagine a cylinder part with a "thread" around it with a pitch of 22mm, the groove is 8mm wide and has radius 4.
Now this would be a simple task to thread with a 8mm round insert.
But instead for better surface and stability i would like to do it with a 3mm round insert.
Can fusion generate the G32 code with alternative starting points and X points?
Best regards
seth.madore
At this point in time, a thread like this is not possible in Fusion.
Seth Madore
