I can't figure out why my generated toolpath isn't cutting the entire perimeter of my part. When I select the geometry the entire part is selected but the toolpath that's generated in both contour and adaptive clear skip over the thicker part of the attached part. I machined this part successfully using different work holding but needed to change it to it's current setup do to stress relieving and tolerance constraints. I copied and pasted the whole program over so I'm really confused as to what's going on. Any help would be very much appreciated.
Roger
