Having a difficult time doing this project, please help
marengmech
Observer Observer
marengmech
Observer
Observer
Hey, just hoping someone can help me out. I know just about enough to be dangerous, not enough to finish this project I'm working on for my wife.
I'm trying to CNC this crib board, I used a 3D adaptive clearing toolpath  with a 6mm end mill, no issue there, but when I tried to use the circular toolpath to clear out the hole for the pegs, I can't select any of the holes to get the toolpath to create, also won't auto detect holes of the same size. Not sure what I've done, but I've tried a few times now and cannot get it to cut the holes. Any help would be appreciated, thanks in advance.
@marengmech - this post has been edited due to Community Rules & Etiquette violation.
a.laasW8M6T
Hi
You have no file attached so we cant see what the issue might be.
Sounds like you may be trying to machine a mesh body, in which case only 3d toolpaths will work as meshes have no selectable geometry
Warmingup1953
At a guess I'd say the tool (with paths) is too large for the hole(s)...But if you share the Fusion file we can have a squiz.
scottmoyse
If you can't select them and they aren't auto detecting... then they either aren't circular or aren't aligned to the setup/tool orientation Z axis. Was this geometry imported from another CAD system?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
marengmech
Observer
Observer
https://mymsn17456.autodesk360.com/data/permalink/DT7cce5QT0bf1342f4f9733124dda78b4660
hopefully this will allow you to see what I’m working on, otherwise not sure how to share it.
a.laasW8M6T
Hi Best to do it this way:
Goto File>Export>Save as .f3d/.f3z then attach to a reply here.
if its an .f3z file you need to drag and drop it as there's a bug in the forum software that won't let you attach them using browse
scottmoyse
That particular link won't no, since we would need access to your Team Hub for that one to work. You can create share links... but the best approach is the one @a.laasW8M6T suggested
Scott Moyse
