Has anyone figured out any good tricks for back spot face milling?
I need to c-bore the back side of some through holes and there is no room to reach them from the opposite side. Our companies previous programmer had manually written the programs for these types of operations. I am capable of doing the same but I thought I would check on here to see if anyone has created a custom addon or post modification that would automate this.
So we want the spindle to be off and the shaft of the tool to go down into the pre drilled hole deep enough for the tool to be put on the shaft and pause (M00) so the operator can do this. Then turn on the spindle and feed move up to the required depth, moves back down, turn off the spindle, pause again to remove the cutter from the shaft and then retracts out of the hole and goes on to the next holes to repeat.
Here's an example:
