haas vr 8 A axis mounted on b axis need a post processor for fusion 360
soorajmjose
Observer Observer
soorajmjose
Observer
Observer
Where to find a post for old Haas VR 8 with A axis mounted on B axis for fusion 360?
programming2C78B
You should be able to just use the generic pre-ngc and enable B instead of A.
Please click "Accept Solution" if what I wrote solved your issue!
soorajmjose
Observer
Observer
I don’t see an option like that in the post..
a.laasW8M6T
No there won't be an option in the post for a VR8
But
If you select the VR8 machine from the machine library
Then edit the kinematic description to match your machine and change the post to the Pre NGC post you might have better luck
It seems the newer VR8 has B on C axis rather than A on B
Andrew Laas
Senior Machinist, Scott Automation
soorajmjose
Observer
Observer
wow… I am going to try that…Thanks
CNC_Lee
@soorajmjose
If the above does not solve your issues or you end up needing further editing, I offer post processor development services and happy to work out a solution for your machine! Message me if I can be of further assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
soorajmjose
Observer
Observer
Hi.  How much does it cost usually?
