haas super mini mill2 with trt100
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i used the haas model (which is close enough) to alter the VF2 + trt100 for the ngc SMM2. simulation seems to work ok, might be some changes needed in the machine setup/kinematics but most seem right.
i defaulted the enclosure to be off , but you can switch it back in the way fusion calls it base as turning it off seems odd, since it turns off the base and not the enclosure ¯\_(ツ)_/¯
same goes for the TRT100, you can just turn it off in the model. i left the direct air gun as as well, and i intend to model more closely the coolant feed pipes for the nozzles
i am making the assumption here the f3d link will include the preview machine builder setup... if it doesn't work i'll export it and post it.
f360 link
i exported it as well https://we.tl/t-d3KnHm75Ym
