Haas ST Lathe - Parts Catcher
rw_skinner
rw_skinner
I'm wondering if the parts catcher can be set to go into position just before the cut off where the parting is near done, rather than at the beginning?  Reason, tired of parts catcher and door filling up with chips and coolant spraying our the door.
So, if you're parting, you have the option to reduce feed rate at a certain radius, typically very near completion of the parting operation.  Would a person be asking for trouble to move the M36 to the section where the reduced feed occurs?  You don't want the tool dragging while your waiting on the catcher, but that seems like a better time than catching all the parting chips right?
(Part1)
N680 M1
N685 T505
(.120 Parting Blade)
N690 G99
N695 G97
N700 S649 M3
N705 G54
N710 M8
N715 M36 (PART CATCHER ON)  MOVE THIS
N720 G18
N725 G0 Z0.5
N730 X1.655
N735 G50 S2000
N740 G96
N745 S281 M3
N750 Z-2.015
N755 X1.355
N760 G1 X1.039 F0.0035
N765 X1.355
N770 G0 Z-1.8603
N775 G1 X1.0503 Z-2.0127 F0.0035
N780 X1.0479 Z-2.0137
N785 X1.0451 Z-2.0144
N790 X1.0421 Z-2.0148
N795 X1.039 Z-2.015
N800 X0.25
X0.270  (Back off a tad)
INSERT PARTS CATCHER HERE
N805 X-0.036 F0.001
N810 G0 X1.355
N815 X1.655
N820 Z0.5
N825 M9
N830 G53 X-4.
N835 G53 Z-2.
N840 M37 (PART CATCHER OFF)
N845 G97
N850 S649 M3
DanielMolloy
Hi @rw_skinner,
There is no reason why the post couldn't be modified to move the part catcher call to where you want, i am curious though, have you hand modified the code to place it where you want and ran it on the machine to check it all works?
rw_skinner
Wow, I replied then it disappeared.
No, I haven't tried it yet.  I was more less asking for opinions in case I was overlooking something like dwelling too long in a groove.
rw_skinner
I think a M35 at the beginning will get the 2 stage catcher in position, then a M36 could pivot it up in place just before the final parting.  This would keep it from dwelling very long in one spot.  I need to try that.
rw_skinner
So this works great....
It was hand edited at this point, but I believe I'll see if I can edit the post to make those entries if reduced feed is checked.
(Part1)
N680 M1
N685 T505
N690 G99
N695 G97
N700 S649 M3
N705 G54
N710 M8
N715 M35 (PART CATCHER READY)
N720 G18
N725 G0 Z0.5
N730 X1.655
N735 G50 S2000
N740 G96
N745 S281 M3
N750 Z-2.015
N755 X1.355
N765 X1.355
N770 G0 Z-1.8603
N795 X1.039 Z-2.015
N800 X0.25
N801 X0.275 (STOP RUBBING)
N802 M36 (PART CATCHER ON)
N805 X-0.036 F0.001
N810 G0 X1.355
N815 X1.655
N820 Z0.5
N825 M9
N830 G53 X-4.
N835 G53 Z-2.
