I am having issues with tapping on my haas machine. The issue is after a tap cycle the spindle does not orient back to the correct location. So what happens is when the tool arm comes into change the tool the spindle dogs are not in the correct orientation and the tool jams in the tool swing arm/spindle. This action only happens after a tapping cycle. After all other tool changes the machine will orientate the spindle dogs to the correct location. I tested this by adding a M19 code after a tap cycle and the machine orientated the dogs to the correct location and then the next tool changed worked as usual. If the spindle does not orientate back to the correct location the tool will jam or the swing arm will not contact the tool in the correct location. This results in the tool being thrown from the tool arm.
Can anybody provide some information on where/how to add a M19 spindle orientation code to the post processor so I do not have to manually add the M19 to the post. I have near zero experience with modifying a post so any help would be greatly appreciated.
