HAAS Post Request
HAAS Post Request
tony
HAAS Post Request
tony
I am trying to get rid of G94 in the Generic Haas post as it is not a valid code on my machine (circa 1992). I did a test program running a peck drilling operation and a tapping cycle.
Also I did switch the use G28 command on however at the bottom of the program is still calls up G53
Everything seems to work ok other then that.
See below
LibertyMachine
I know just enough about post editing to do simple things like this. Please test carefully!
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
tony
Thanks I'll give it a try.
tony
Seems as though the post is still out putting a G94 in the first  tool. Please see attached code. I also noticed that a odd tool number within each tool, if the current tool is T1 then the next one T2 is listed down below.
I also included the post file. Hopefully you can help again.
Steinwerks
I've removed every instance of G94. Test carefully, and I assume you're not using a rotary, correct? This post might break that if so.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
tony
Ok i'll try it out. Right now I'm not using rotary but might be in the future.
