Hi all
I'm sure this has been discussed previously and should be straight forward, but I've always struggled to get an optional stop to work how I want it to, this is to be able to post out from Fusion with an Optional Stop inserted only where I want it. For info I’m running a 2022 Haas VF-2 with NGC.
So, previously if I have 'Optional Stop' ticked in the Fusion post properties AND the Optional Stop button enabled on the Haas control, it will stop at every tool change. Turning off on the control (still ticked in the Fusion post properties) it doesn’t stop at all. All as I’d expect.
However, with Optional Stop still ticked in the Fusion properties AND the control button switched off, if I’ve inserted an Optional Stop Manual NC line in my Fusion set up where I want the stop, it ignores it.
Only way I’ve managed to get it to work is as follows:-
Fusion properties Optional Stop NOT ticked
Optional Stop button on control ON
Optional Stop Manual NC line in my Fusion post where I need the stop
But, regardless of whether the Manual NC command is set to ‘Optional Stop’ OR ‘Stop’, the machine does the same thing, the spindle retracts only to the retract height and stops.
I really wanted it to retract to the tool change height before the stop. Yes a workaround is to just set he retract height much higher.
So, could someone more knowledgeable than me kindly confirm that all of the above is correct and just how it is? Yes I could manually edit the code, but would rather not, I’m not very confident with g code editing.
Many thanks!
Andy
