Haas CL-1 Lathe live tooling needs X axis inverted
programming2C78B
Advisor Advisor
Message 1 of 1
programming2C78B
This is from Fusion/haas, but unless we are setting up tools wrong, the X axis numbers all need to be inverted in the code!
The live tools come in from the (away from operator) position. We touch the tools off from the "back" of the part and enter a negative dimension. The code works great if we throw a -sign infront of the X and R dimensions.
If the numbers are positive, the tool cross over the center line and through your part.
Please click "Accept Solution" if what I wrote solved your issue!
Replies (0)
