I have a guitar headstock to mill out and I'm having a heck of a time trying to figure out what the best strategies are. The tool paths I've created are letting me down. Hope someone out there has some ideas.
Here's a path to the headstock design...https://a360.co/30uUVUo
There are two particular things stumping me.
1) How do I create a cutout using tabs in one operation by milling from the top, and milling through at least to the bottom of the model? I can't seem to get a toolpath to work...and I've tried several. My guess is that I'm not selecting the geometries properly (?) The paths seem to carve all the way through the body toward the truss rod slot.
2)...and that brings me to the truss rod slot....It's a sloped geometry, and I've had a lot of failure just trying to mill out that truss rod slot where it exists the neck. I'm hoping someone out there can humble me on what I'm doing wrong while toolpathing this dang truss rod slot.
My "thank-yous" in advance. Even just some ideas are great learning points, even if they don't remedy my problems. I'm only slightly beyond being a beginner with generating toolpaths in the Manufacturing tab. (I'm using a Shapeoko 3XL, if it is helpful)
Thank you in advance,
Harold Stevens
