Message 1 of 21
Hello, I would like to ask how to correctly generate G-code for the Prusa MK3.9 or MK4 printer using Autodesk Fusion. There is no preset for these printers in the Fusion Machine Library. In the past, we used the Prusa i3 MK3S, which is available in the Fusion Machine Library, so I had no problem with the export. Is the older profile compatible with the printer after the upgrade? Is it possible to get profiles for newer versions of Prusa printers for Autodesk Fusion somewhere?
