Gang lathe need X before Z in post
marc7X3XJ
Message 1 of 11
marc7X3XJ
Ok, I have gotten decent code out of the CNC NEW PP now as far as direction of tool approach goes but now I am having a little issue with tool change commands. I just dragged an expensive carbide drill across the face of a test part. After the drill operation it retracted to the safe plane but on the next tool call the Z move was first and for some reason the boring operation was starting about .002" into the part instead of at the safe plane. I need to look at the file and try to figure that out but seeing how it is a gang lathe I think that the PP should write the X move before the Z move on tool changes because all the tools should be at the safe plane retract from the prior operation. Can someone help me figure this out or is there a very specific reason why it is not done this way?
Also the programs written by the PP are ending in a M15 and not an M30 so some help on that would be great too.
Thank you,
Marc
Replies (10)
Message 2 of 11
daniel_lyall
You need to add the post you are using and what machine and control?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 11
marc7X3XJ
The control is a GSK 980TDc and I am attaching the post now.
Thank you,
Marc
Message 4 of 11
marc7X3XJ
I figured out how to reverse the X-axis and Z-Axis output using Visual Studio Code so now the only small issue that I am having is that there is no M30 generated at the end of the program. It is not a big deal to add that but it certainly would be more convenient if it was generated from the PP.
I am attaching the revised PP (original PP is posted above) and the code generated from each in case this can help anyone else using a CNCNEW machine. Please be sure to check the PP thoroughly on your own because I am new to this and will not take responsibility for any problems that arise from the revised PP usage.
Does anyone know how to get the M30 to generate automatically?
Marc
Message 5 of 11
daniel_lyall
If the M15 is not meant to be there and is in the spot where M30 should be change the 15 to 30.
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 11
marc7X3XJ
It looks like the PP puts in the G15 at the end of each operation. I am looking at the end of the cps file and I do not know enough about them to add or modify where to put a M30  when I program ends.
Message 7 of 11
daniel_lyall
Does the M15 need to be there and do you use a C axis?
it is on line 253
 case "ENABLE_C_AXIS":
    machineState.cAxisIsEngaged = true;
    return (spindle == SPINDLE_MAIN) ? 14 : 14;
  case "DISABLE_C_AXIS":
    machineState.cAxisIsEngaged = false;
    return (spindle == SPINDLE_MAIN) ? 15 : 15;
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 11
marc7X3XJ
The machine does have live radial tools but I am not using them on this part. The M15 is doing no harm here. Not having the M30 is is the real issue that slows me down a little if I forget to manually add it.
I have searched my Haas PP for "30" and there are only two instances and only one of those appears to be related to mFormat at the end of the PP. I have copied and pasted the following line after the (COMMAND_END) ;  in my CNC New PP
writeBlock(mFormat.format(30));
This seems to be working but please let me know if there is a better way to accomplish this or if I did it correctly. I will include my new complete PP if anyone want to check it out.
Thank you,
Marc
Marc
Message 9 of 11
daniel_lyall
That is what I was going to suggest you do.
Daniel Lyall
The Big Boss
Mach3 User
Message 10 of 11
marc7X3XJ
I figured it had to be something simple but I was worried that I could screw the whole thing up without the help of a pro.
Marc
Message 11 of 11
daniel_lyall
I am definitely not a pro, I have just been doing it long enough to know what goes where.
Daniel Lyall
The Big Boss
Mach3 User
