G84
G84
thierry924K4
Message 1 of 10
G84
thierry924K4
How do you enable g84 code?
I can not find it...
Replies (9)
Message 2 of 10
mattdlr89
Use a drill cycle and select "Tapping" under cycle type. When you come to post process your code it should output G84 assuming your post is set up correctly.
Message 3 of 10
thierry924K4
I does not show up in my post, is there anything I should do when I am posting it?
Message 4 of 10
mattdlr89
What post are you using?
Message 5 of 10
thierry924K4
Can you see this picture?
[cid:image001.png@01D8A0F1.2546F780]
Message 6 of 10
mattdlr89
That picture has not worked. In order to help if you can let us know your post processor and the Fusion file too just to check all the settings are correct.
Message 7 of 10
thierry924K4
please check attachment for 3 files I hope you can help me 🙂
Message 8 of 10
mattdlr89
Ah I now understand. It is outputting G95 instead of G84 because you have the "Live Tool" selected in your tool library for the tap.
I assume you have a static tap holder and the spindle will be rotating when you tap. For this you need to uncheck the
"Live tool" box in the tool. See screenshot below then it will output a G84 instead of G95.
G95 does this - G95 Live Tooling Rigid Tap (Face) (Group 09) (haascnc.com)
Message 9 of 10
thierry924K4
Hi, thank you for checking,
I do not see the G95 in my post, and I am doing this with a live tooling because I have off centre holes that need tapping?
Message 10 of 10
mattdlr89
In the file you shared above of the code it uses G95. I don't have a Haas lathe so I'm not entirely sure what you need to do but I think G84 is for when the tool is static and G95 is for live tooling? I'm sorry I can't be of more help.
