G83 Lathe Canned Cycle
info99H4D
info99H4D
The standard HAAS ST20 post won't post I J & K values when a reduced pecking depth is specified in Fusion 360.  As a workaround I was advised to modify the post and this seemed to work quite well although for some reason it no longer seems to be working.  Please see a screenshot of the post below.  Does anyone have any suggestions?  I use this feature quite a lot and would be very grateful for a solution!  (post attached)
boopathi.sivakumar
Hi @info99H4D
I cannot able to replicate the issue as you mentioned, If you are using deep drilling cycle, it should work fine. Could you please attach the F3d file. So that i can have a look into it
File>Export>.F3d
save the file and reattach the file to this thread.
Boopathi Sivakumar
Senior Technology Consultant
info99H4D
Many thanks for your reply.  Please see the f3d file attached.  As you can see from the 10.2 mm drilling operation I have selected the deep drilling cycle with a 12 mm initial peck, 2 mm reduction and 2 mm min pecking depth.  I would like this to post as G83 X0 Z-47.112 R0.087 I12 J2 K2 F0.2 but instead it is posting G83 X0 Z-47.112 R0.087 Q12 F0.2.
boopathi.sivakumar
Yes!! the generic post for Lathe machine prefers single Q peck value, In some machines IJK causes error, thats why it is using Q by default, But as you said the modified post which you have attached works perfectly for me. I got the expected output as
G83 X0. Z-47.112 R0.087 I12. J2. K2. F0.2 Could you please check that you are using the modified post not the generic post.
Boopathi Sivakumar
info99H4D
It seems as though that was the issue.  I had modified my machine in my machine library to use the new post but for some reason looking at the setup the machine was using the original unmodified post.  I suspect that when creating the setup I had another document open that was originally created before the post was modified allowing me to select the machine with the old post.
Thanks again!
ed
As of post version 43861, the "chip breaking" drill cycle still outputs a G81 not the correct G83 so it does full retracts every time.  Can we please get this fixed without having to manually modify the post.
