fusion360 gcode causing z axis to drift up during cut
z axis drifts upwards during cut until it no longer reaches the material. It starts out normally where its supposed to be and it just starts heading north?? ugs reports the numbers correctly. If I stop the program when this happens and return to zero it is sometimes 10mm above the material?? Everything glides smoothly. No slipping or steps skipping. I have bumped the voltage up and tried with no luck. Everything is tight and seems normal. This doesn't happen with any other program but fusion. Any help is appreciated. Thanks
