Fusion turn Groove suppression does not work
marcus.toepke
Advisor Advisor
Message 1 of 17
marcus.toepke
Hi all!
I have created an exercise part for turning. Nothing wild!
When I try to use groove suppression, Fusion calculates forever and stays at 0%
I know how to get round the problem, set the rear boundary differently or 100 other possibilities. But I'm interested in why it doesn't work, what am I doing wrong?
I tip on a E70 Error, but I can't find it!
Replies (16)
Message 2 of 17
Christoph_360
Hello
If you only select one face of the groove, it works, but I myself have too little experience in turning to explain the relationships.
(view in My Videos)
Mfg
Christoph
Message 3 of 17
marcus.toepke
That's funny!
That's exactly what I tried!
I've just tried it again and it doesn't work for me!
(view in My Videos)
Message 4 of 17
Andrew_Todd
Hi Guys. This could be a possible bug. I will look into this now for you and report back. Thanks.
Andrew Todd
Software QA Engineer
Message 5 of 17
Andrew_Todd
@marcus.toepke- Just for your FYI when I generated the tool path at my end it calculated fine using the parameters you specified.
Andrew Todd
Message 6 of 17
akash.kamoolkar
@marcus.toepke I cannot replicate this issue in the latest update of Fusion that recently went out. Could you check again, after updating your Fusion?
Akash Kamoolkar
Software Development Manager
Message 7 of 17
marcus.toepke
OK I have used the repair function.
After that NOTHING it don't worked.
Then I copied the sketch and build the solid to manufacture new.
Now it works but I must select the full groove.
Then I build a Very simple model with two groves
If I select only the buttom of the groove:
If I select the full groove:
Message 8 of 17
kuhnjst
I have also been having a lot of problems with this. It used to work then it didn't and hasn't for some time now(months). I have installed all of the updates in normal Fusion and the Insider and it still doesn't work.
Message 9 of 17
akash.kamoolkar
@marcus.toepke I'm not sure I understand the issue. Yes, you have to select the walls and the floor of the groove for Fusion to recognize the groove. This is by design.
Akash Kamoolkar
Message 10 of 17
akash.kamoolkar
@kuhnjst Could you attach a sample file that used to work with groove suppression enabled and now doesn't?
Akash Kamoolkar
Message 11 of 17
kuhnjst
I never had a file that did, then didn't, work. I had 1 file that did. The 1st time I used groove suppression it worked (no longer have that file. IT was when I 1st installed Fusion So just over a year ago.) Then any time after that, when I tried to use groove suppression, it didn't work.
Message 12 of 17
akash.kamoolkar
@kuhnjst if you have a file that doesnt work with groove suppression, any file, i'll be glad to take a look.
Akash Kamoolkar
Message 13 of 17
kuhnjst
i cant post anything on the public forum. I can submit a ticket through Autodesk and attach your name to it?
Message 14 of 17
akash.kamoolkar
@kuhnjst you can either send me a private message or email me at akash dot kamoolkar at autodesk dot com.
Akash Kamoolkar
Message 15 of 17
kuhnjst
I can only submit models/projects to Autodesk customer support due to NDA requirements.
Message 16 of 17
akash.kamoolkar
@kuhnjst yeah you can send it to support then, requesting them to forward it to me and i'll take a look.
Akash Kamoolkar
Message 17 of 17
akash.kamoolkar
@kuhnjst Thanks for sending over your file, I have verified that the groove suppression problem you reported has been fixed in an upcoming update. I will update this thread when it is released to the public.
Akash Kamoolkar
