I am new to CAM and have a quick question regarding tool libraries. I currently have a tool library in Fusion 360 called "CNC12 Tools". This library contains the 10 actual tools that I currently own. Each tool has a unique number. My milling machine controller (Centroid) has a duplicate of this library with the exact same tools and numbers.
Everything seems to be working well as the tool numbers in Fusion have the same number as the Centroid tool numbers.
My question is how you import other tool libraries when the imported tool library has the same tool number as the existing CNC12 tool library. It is my understanding that I must match the tools numbers in Fusion to the tool numbers in Centroid. Do you simply use the renumbering function to renumber the tools in the library that you want to import? Is there another way to coordinate this?
Thanks... Richard.
