Fusion stops responding when trying to post again
FrodoLoggins
Advisor Advisor
FrodoLoggins
Tried posting from setup 1F (Downright).
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Richard.stubley
Hmm just tried and works fine for me.
Can you give a bit more info.
Does it produce the code, but then hang when you try to do something else?
What post are you using and if its custom can you attach it.
Do you see the same behaviour if you use NC programs?
Richard Stubley
Product Manager - Fusion Mechanical Design
FrodoLoggins
Right click on setup > Post Process > Post dialogue appears > Hit OK > Then I get the beachball of death.
Code is not generated.
It's random. Posting usually works fine, but 5% of the time Fusion stops responding.
Happens with both posts attached. They were downloaded from the HSM post library and uploaded to my personal cloud library. The HAAS post was not changed in any way. The ProtoTrak post file name was changed to "G-Code" and the description was changed to "3 TRAK". Nothing important was changed. See attached image for clarification.
I don't use the NC program functionality, not really sure what it does.
Richard.stubley
Hi @FrodoLoggins,
One question I should have asked Mac os, or windows?
I will see if we are getting any other reports of this.
The NC programs dialog is similar way of posting, but it has many other uses one being it keeps a record of what you have posted so you can see a record of the tool-paths you have already run.
Richard Stubley
FrodoLoggins
Thanks. MacOS. Fusion not responding when posting has been an issue ever since I started using it, probably 1.5 years with 2 different Macbook Pros.
