Have a bit of an emergency here – doing my first 4th axis stuff on the Tormach (have done it before in Mach3 on my router with 4th) and I managed to generate the toolpath but when I post process, fusion doesn’t actually output any code! Just an empty file.
I’ve downloaded the latest PP post processor and uploaded it to my cloud.
Any ideas?
p.s. I actually also made this toolpath in VisualCAM and it outputs fine but the feedrates are all messed up so I'm trying F360 in case it's something in the post. The feedrate is set to 9ipm but the feedrate is constantly changing and it doesn’t seem to have rhyme nor reason. I understand that feedrate should change with Z depth but it doesn’t. I can’t seem to figure out what’s changing the speed but something is. As an example, while ramping down, the feedrate display on PP shows a rate of like .1ipm but the angular velocity is actually much higher than when it’s cutting the slot and reads 9ipm.
This project is due tomorrow and this is the last op! Please help!
