Fusion not including Planar Gcode (G17) on operation post process
zdesignstudio
zdesignstudio
I have been using Fusion in the free mode for a long time and have not had any issues or weird anomalies. I just recently subscribed to a paid version and now when I post an entire Setup at once and have them split by tools, the first tool contains the G17, G20, and G90 G94 commands but every additional tool doesn't contain those parameters and thus doesn't function correctly.
If I post the tool operation by itself like I was doing in the free version since it was a requirement, its posts with the code just not if i do it as an entire Setup.
Setup Post
Tool 1
(1001)
G90 G94
G17
G20
(Flat3)
T1
S8000 M3
Tool 2
(1001)
(Flat1)
T2
(CHANGE TO T2)
S8000 M3
Posting Ops Individually - Has information
Tool 2
(t2)
G90 G94
G17
G20
(Flat1)
T2
S8000 M3
Will
AchimN
Hi Will, which postprocessor are you using?
Achim.N
Principal Technology Consultant
zdesignstudio
Its for a Langmuir MR1.
Would it be located in there? I wasnt sure if it was in the PP or a setting in Fusion somewhere.
AchimN
The post you are using is not one of our generic posts in the library, but it seems that it is almost identical with the GRBL post we have:
https://cam.autodesk.com/hsmposts?p=grbl
Please give this post a try, it does post out all relevant G-codes including G17 at the beginning, also when you split programs per tool.
Achim.N
