Fusion Manufacturing model "missing"
beredesigns
beredesigns
Community Visitor
Community Visitor
I Was working on a project last night and saved everything properly and waited for upload to complete and shut down my computer. When I went to work on it again today it says my manufacturing model is "missing" when I hover over the setup error it says "no model selected. All models/ solids will be used". In the past this has happened when I edited the sketch in design but i was always able to go back into the setup and re select the object i needed. i tried deleting the setup and making a new one and it still wont let me select the 1 object i want to make a setup for. Instead, it wants to select the entire Manufacuring model, which has many different items on it.  i am using this for cnc plasma cutting. this is a very important step because it sets my work zero on my cnc table. See attached screenshots to see exactly what im seeing
tigersonicsaudiodesign
Community Visitor
Community Visitor
I have been having issues recently with Manufacturing models vanishing entirely, causing the same errors when it comes to missing models for machining...this has happened with two entirely different files so far since last update, after logging out and back in again and trying the usual tricks, still no change.
I would like to know the solution, as loosing all manufacturing models and ability to alter designs that are in current production is a serious problem.
seth.madore
I think this is the first I've heard of the issue, but it does sound serious. Can you capture this behavior in a screen recording, or share files that demonstrate the issue?
Seth Madore
Community Visitor
Community Visitor
Fusion Manufacturing model issue.mp4
Attached is the video of the issue I am having with manufacturing models
going missing, even after saving.
This is on my work account, KHZ ltd under my colleagues email
[email protected]
Never had this issue before, but is consistent to this file.
seth.madore
If you are replying by email, attachments do not come thru. You'll need to return to the forum on your computer and attach there instead.
Seth Madore
luke_cody
I've been having the same issue on multiple models. Has anyone here figure it out yet?
I have also shown this to two Fusion Techs and neither one has given me any fix, or even an answer about what is happening.
