08:57 PM
I am testing a simple lathe part using a grooving operation. the stock diameter is 0.5 and the finish diameter is .48".
in all the posts I have tried, the output shows all radial positions exactly double the correct dimension. the part finish pass should be radius .24", but it is .48". The clearance position where the program starts should be at .65" radius, but it is at 1.3" radius from the z axis.
I have checked the part repeatedly, and it is .24 radius, .48 diameter. with the program it will come out .96" diameter.
Nothing in fusion 360 shows anything incorrect, but all 5 lathe posts do the same thing.
Any ideas?
