Fusion g code runs well but erases work coordinates in candle at the end of the program
jscott6SWZG
Advisor Advisor
jscott6SWZG
I need the g code to allow candle to remember the work cooridinates at the end of the program...so I can flip the part and continue.
I checked the gcode the end is a m30 command end of program return to top of program.  Can i just delete the m30 command...
If so how can i make fusion 360 do this automatically.....
What other fixes are there wo I retain the work coordinates
mattdlr89
M30 is program end and reset.
Do you want to replace it with a different code to end your program or just nothing?
The post processor can be edited to output whatever you need. What post processor are you using? (.cps file).
