fusion exported g-code incomplete
shirm
shirm
Community Visitor
Community Visitor
after exporting a g code from the manufacture tab in fusion (for mach 3) i opened the g code in mach 3 and it was only half (or less) of the model
programming2C78B
And if you put it into ncviewer.com ?
Please click "Accept Solution" if what I wrote solved your issue!
emburamanaut
Observer
Observer
I'm getting a similar problem. After generating the NC Program, my GCode file ends abruptly, Fusion randomly cuts the gcode half way through.
Does not seem to be a subscription limitation though.
I'm still searching for a solution for this.
Thanks!
seth.madore
Replied to the thread you started on this topic 🙂
Seth Madore
