Fusion cutting corners of stock not displayed in simulation, using excessive retracts when I try to do something about it.
Greetings,
Can someone tell me why Fusion won't show my cutting tool (1/4" straight mill) slashing through corners of my stock when it doesn't retract? This would be a really useful thing to show in a simulation, and save me a lot of energy fooling around. It took two diagonal paths through the corners, and perhaps would have taken some more. I would upload my setup, but I have already changed settings again and so won't be able to reproduce it accurately.
When I do raise my retracts I get very frequent retracts that waste a lot of time and put more miles on my robot. Is there some reason the software can't avoid running the tool inside the area I am trying not to mill?
What is especialy annoying is when I set the retracts to stay down and set lift heights to zero, Fusion says:
Warning: Lifting retract height to safe height.
Warning: Lifting clearance height to retract height.
Why would the software tell me it is retracting to a safe height when it seems to do no such thing? I ran that iteration and it didn't retract at all.
Is it really that hard to ask the path not to hit the parts of the stock I don't want to mill? Is solidworks any better about this? It is just so fiddly. How can I ask it to move out of the way when it needs to, but not when it does not need to?
I would really appreciate a visual of the cutting tool removing material everywhere it goes, including retracts, or non-retract linking.
For now I'm going to try minimum retraction, preserve rapid movement, allow rapid retract, safe distance 8mm, max stay-down 800 mm, lift height zero. Does that seem reasonable? I am cutting to several depths using a pocket clearing strategy. It's just so frustrating that there are SO many setting to play with here, and I think we all have the same goal - reduce and smooth our paths whilst avoiding hitting the stuff we didn't ask to cut.
Specs: I am running this through the grbl post to create an NC file, then using RoboDK to translate that path to a set of coordinates my Staubli Rx90 robot can understand. It works surprisingly well - I just need Fusion to do it's thing 😉
Thanks!
David Earle
