Fusion 360 RPM Speed Limit Cap
mattXTRM9
mattXTRM9
Hi, I am learning Fusion 360, my machine can go up to 12000 rpm but we normally cap it at 11000rpm as a company policy. Is there any way to ensure that I can't post a file with a rpm over 11000.
Matt
a.laasW8M6T
Yes
The post processor can be modified to generate an error when the spindle speed is too high.
If you use Machine configurations you can set an RPM limit there too but it will only give you a warning, it will still let you post the code.
If you share your post here we can have a look
Andrew Laas
Senior Machinist, Scott Automation
marcus.toepke
I have modified my postprocessor this way, that if rpm become over a limit, the post put out the max prm.
Since I work with on my machine with VC cutting speed and feed per thooth is so then no problem
mattXTRM9
Thanks for the replies guys, we are getting the post modified for a couple of other issues so I will get a limit added to the post, but I set the machine configuration as well to be sure. Cheers.
