Fusion 360 Rapid Collisions?
dwarfkiller435
Observer Observer
dwarfkiller435
Observer
Observer
From what I've seen from scouring the interwebs is that my issue is rapid collision, I could be wrong but its my best guess so far. The issue I'm running into is that I am getting random collisions with fusion 360 CAM, that are completely randomized, I think it has to do with my stock But I could be wrong. Any help on this would be much appreciated, as I'm on an FRC team and trying to machine some important parts for our team, thank you in advanced for any help you can provide. I'm also providing this link to the part so you can check it out and see if you can find the issues, just copy it-into web browser and you should be able to download it into fusion.
https://a360.co/3nKrzyq
HughesTooling
This is only because you have no lead out and the rapid is touching the side of the hole. Probably should error on all holes but there's going to be some differences just down to tolerance.
If you enable lead outs with a small rad these all go away.
Mark
Mark Hughes
Owner, Hughes Tooling
