Fusion 360 length and diameter offset while creating a tool - what do they do ??
Aadithya01
Advisor Advisor
Aadithya01
I found that the length and diameter offset I haven't used those options but I am curious about what do they do ..
IS THERE ANY TUTORIAL EXPLAINING THESE OPTIONS .. IF SO KINDLY SHARE THE LINK BY POSTING IN THIS FORUM
LibertyMachine
It's not really on "option" in CAM software.
There are 2 main types of controls and methods for controlling a CNC machine. The first type, and this is found in the low end GRBL, kosi, DIY crowd is to simply produce XYZ code. There is no adjustment that can be made in the control to adjust for tool size, wear, part deflection, etc. It's all in the code. If you need to adjust it, you go back to Fusion, make your adjustments and post out the code again.
The other, more common, flexible and more powerful control system is found in more commercial applications such as Haas, Fanuc, Siemens, Mitsubshi etc.
While there are a few "DIY" control options that employ these same approaches (Mach3, LinuxCNC) it tends more to the commercial side. This method injects certain bits of code into the program. This is the letter values of T and D. T is your tool offset where you define (in a manner) the length of the tool. This could be the distance from Z zero to the top of the part, or simply the gauge length of the tool and toolholder. This is dependent on the machine configuration and what options are available. The "D" address allows you (in the control) to adjust the size of the tool to adjust for blends, part size etc. This is typically expressed in the control (not Fusion) as either half the diameter of the tool (Control Compensation in Fusion) or simply left at a value of zero (Wear Compensation setting in Fusion)
If this is something you have never touched, and you've not had any issues, I would suspect that you are running a machine described in my first paragraph. I'd just continue running as you are, as it most likely wouldn't apply to you. Out of curiosity, what ARE you running, what control, what machine, and you've successfully run parts?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Aadithya01
HEy LibertyMachine ,
Thank you so much  . I actually work in a company named USAM CADSOFT which is an autodesk silver partner and deals all manufacturing and Civil softwares of autodesk and I work as an application engineer ..  I have been working with Inventor Proffessional , AutoCAD Mechanical , Nastran In CAD and Fusion 360 ultimate basically taking care of the manufacturing portfolio at our company ..
Till today I have done benchmarkings with customers having FANUC , SIEMENS 828D , heidenhain .. These are the three controllers that we mostly find in our region ..
Thankyou so much for describing about the length and diameter offset ..
