Flow/Blend: Same stepover/cusp values specified on similar geometry but much different results?
eerier_bleach0f
eerier_bleach0f
Settings:
Screenshot 2024-07-12 at 10.26.05 AM.pngScreenshot 2024-07-12 at 10.26.12 AM.png
Changing the blend's stepover calc to "on surface" yields much closer results but there's still 2 more passes than the blend.
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
programming2C78B
Posted this before too, also with Scallop. I ended up just looking at the toolpath data and finding what the "real" stepover was! I find for scallop I basically double what I want to use (is it considering the gap that it does on an entire loop instead of per stepover?) and no one at Autodesk could explain the math behind it. Sad.
Please click "Accept Solution" if what I wrote solved your issue!
