I use Flat a ton since it's so convenient and safe. I use expressions to control most everything on my parts and as such utilize Set as Default frequently. The one toolpath that doesn't have a Set as Default for an option I wish it did is Flat, specifically under Passes, the Max Deviation %. Does anyone have a workaround to set the deviation to whatever value and then set it as a default?
I looked at the Suggestions board, but there's only Fusion Manage under there, nothing for Fusion or Fusion Manufacture extension.
