File corroption? Fuison keep Crashing
Linus_Follinger
Linus_Follinger
I have this file  that Crashes every time i hover or click on the two last operations.
does anyone know why? is there somthing wrong in the file?
this has happend to other files and i have to make new ones and redo all the cam work.
Any input is appriciated 😃
a.laasW8M6T
Hi
I can replicate the crash, I have tried several things to try to prevent it(changing Spun Profile algorithm, turning off IPS) but it still crashes.
Unfortunately I'm out of ideas how to fix it(I have summitted the file for analysis to Autodesk)
Andrew Laas
Senior Machinist, Scott Automation
Linus_Follinger
Hi, thanks for taking the time to look into it.
a.laasW8M6T
Hi
I spoke to one of the developers and they found a workaround to fix this file is to change the stock to fixed or relative cylinder rather than from solid
That stops it from crashing.
Andrew Laas
