Fetching Tool Parameters (Pierce Height, Pierce Delay, Cut Height) in Mach3 Plasma Post Processor
I am currently working on modifying a Mach3 Plasma post-processor and I'm having difficulty fetching specific parameters directly from the tools in Fusion 360. Specifically, I want to pull the following parameters from each tool:
- Pierce Height
- Pierce Delay
- Cut Height
I've tried using tool_pierceHeight and other similar parameters, but they don't seem to be working as expected in my post. In other posts, like the OpenBuilds post, these values are fetched from the tool properties without issue, and I would like to achieve the same in my Mach3 setup.
I have attached my base Mach3 Post (which has some small edits to the original but works with manual height and pierce settings) along with my wonky one I have tried to edit 30 times to get the tool_pierceHeight to be fetched, the edited one crashes apon post, I think the issue is with onOpen, I have also attached Openbuilds and Firecontrol posts which both seem to pull the tool settings a different way.
Any help, guidance or tips is much appreciated.
Thank you!
